I've just done a job for my dad in his old peoples flat and I've had to make a modification leaving me stuck for ideas.
I've swapped several of his night storage heater for newer, more effcient and better looking units. The old storage heaters had a double spur socket connecting them to the mains but the new ones are now only a single spur connecting them.
My problem is.... I've had to change the size of the white plastic plate and back box to a single sized socket. This is fine on the 3 walls where the contruction of the wall is a solid brick wall. With these I'll simple render over them and the use multifinish for the last few mm's.
Oh while I'm here... what's the best best plaster to use to patch areas like this? In other words now plastering the whole wall but simply applying a finishing coat to an effected area.
My question is... how do I fill the gap left by the one that's a dry lined wall with blocks behind it. In other words.... one of them is fitted to a dry lined wall and therefore has a large drafty void behind it.
