Hi all
I'm put up a kitchen wall unit next to a full height unit. I've made a bit of a mistake because I forgot to put the cover panel on the side of the full height unit (15mm thick).
This means I've had to take down the wall unit, and will need to put it back up again 15mm to the left of where it is currently. The wall unit is held to the wall with two screws in the top corners. so the old holes and the new holes are too close together for comfort. I put it up and the plug in the new hole is very loose. Is there anything I can do to fill in the holes I've drilled and then re-drill them so the plug is secure?
David
David
