- Joined
- 16 Jan 2022
- Messages
- 3
- Reaction score
- 0
- Country
Hi All,
I hope you can help me with an odd issue with my Ideal logic combi -35 boiler.
At this time of the year (winter) the pressure of the boiler will drop below 1 bar and I would normally top it up by using the filling loops valves.
Normally, this works fine.
However, in the last month the filling loop only seems to ad hoc of the time.
When the filling loop is working you can hear the water running through the loop and the pressure going up.
And the valve is easy to open.
When the filling loop is not working, there is no flow sound of water.
And the valve is hard to open.
But when I turn the central heating off for a few hours, then back on again. Then use the filling loop, it will work again.
Its like it will only work if the boiler is cool.
It’s very odd.
Has anyone experience this issue before and what can cause it?
James
It’s very odd.
James
