For some reason that I can't understand my 27CDi Worcester Bosh does not have the filling system shown on the installation instructions, which denotes that the system is filled using a key.
I am totally familiar with this as it was on the boiler in my last house, which was a 24CDi.
The 27CDi has a steel braided hose on the underside of the boiler with 2 connections and 2 cheap plastic-handled in-line valves of the type you might use to plumb in a washing machine if you weren't too fussy. I am surprised at Worcester Bosh using such cheap fittings on a top of the range boiler!
I can remember the installation engineer showing me how to fill the system. One valve is the inlet to the CH system and the other valve is the filling valve from the mains.
The problem is that the cold water inlet valve will not move, indicating that it has seized up. The boiler has only been topped up once in 20 months! I am frightened to use force on the valve in case I break the handle it as it has a small cheap, tawdry plastic handle.
Please advise. I have used wD40 to no avail!
