fire door lining
11 Apr 2010
Cambridgeshire
Hi. I'm fitting a fire door lining (FD30) and am not totally clear on what is acceptable material to fill any gaps between the frame and rough opening - wondered if anyone would be kind enough to clarify? I've read various websites that say use mineral wool for gaps over 6mm, mastic if the gap is smaller, others say you can use plaster or other fire resisting material. Also is fire resistant expanding foam acceptable?
the foam is extremely good for filling irregular gaps between lining and wall, it also expands, sticks, and sets rigid so it holds the frame firmly in position with no rattle or shake and it will not come loose when your teenage daughter keeps slamming the door.
However it needs practice to get a neat finish (I block the gap with a batten wrapped in clingfilm, and inject through drilled holes) and I believe there is a maximum gap size it is rated for. might only be 6mm? though I have used it to fill far bigger cavities, provided there is something covering them. It blocks noise and draughts as well as smoke (so does the furry pile strip, and with a carefully trimmed door, it helps the door shut quietly).
You can trim the foam back once hardened with a breadknife, and it will accept filler or paint. The architrave will hide it anyway.
The mastic swells with heat, the foam doesn't, so is suitable for a permanent fixing like a dooor lining, but not a working gap. I reckon it is far better than mineral wool because it sticks and form a solid block.
