What happens when the fire brigade arrive at a serious house fire in relation to electricity. Does it have to be disconected first? What about in factorys etc.
but my thinking is they do not worry about it since the hose is non conducting, and life comes first.
however if it is high voltage (neon sign for example) there is a red "fire mans switch" which isolates the supply to the sign.
No fire brigade will go near a house with water until the power has been isolated. This is normally done by flicking the main switch inside the door. If this is not possible then the seal is broken and the cut-out removed. In the unlikely event of access to this being a problem the supply company will have to be called (in our case me!) The supply board will be able to isolate the property or area very quickly but this is unusual.
In the case of industrial or commercial properties, it can be more complex and more critical to isolate the supply. If it is possible to gain entry to the switch room/service entrance it will be isolated there. But more often the supply board will be called, who will isolate the supply at the distribution transformer (by shorting 10KV to ground if necessary)
