The delivery crew who recently arrived with my new range cooker had to take it away again because of a regulation about fireproofing next to the gas hob - there is a cupboard fitted on top of a breakfast bar which is 60mm away and apparentlly needs to be at least 150mm or fireproofed. There is already a range cooker in the same position, with no evidence of scorching, but apparently the rules have changed since this was installed. behind the cooker there is a steel splash back. The ideal solution would be to put the same steel onto the side of the cupboard in question but I can't find anywhere which will cut steel to size, the alternative appears to be to tile it which whould be horrible. Any thoughts?
