Fireplace: Building a structure to tile
4 Apr 2010
Cheshire
Gents,
I'm looking at constructing a fireplace surround to be tiled. I intend to use the fireplace in the future, would a wood and ply box construction be suitable once tiled, or would these be inappropriate due to the proximity of the heat?
Thanks in advance.
No not if the fire is to be anything other than a visual feature with little heat output
Yes, as above.
Have a read of this lot but not all may be relevant to what you want to do.
Unless installed by a HETAS registered installer, a new stove or open fire installation must be notified to your LABC (fee involved) Unless you use a HETAS installer, the fire installation & flue must be inspected for Building Regs compliance & a certificate issued which you must have for your own safety & for all important insurance purposes in the event of any future problems.
For stoves specifically, Part J Building Regs, is what you need to comply with;
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADJ_2010.pdf
This site is also very useful & more user friendly;
http://www.stovesonline.co.uk/stove_building_regulations.html
In addition to a flue/chimney you will need a constructional hearth, ventilation & a notice plate giving details of the installation. There are other considerations regarding the type of materials you should use around a stove due to the heat they generate, for example Gypsum plaster or plasterboard shouldn’t be used as it will not withstand more than 49 degrees C & will break up. Lots of archive threads on stoves & other things you need to watch out for, here a few links for you to read but not all may be relevant to you:
http://www.hetas.co.uk/public/certificates.html
http://www.solidfuel.co.uk/pdfs/buidling_regs_consumer leaflet.pdf
http://www.diynot.com/forums/viewtopic.php?t=183614
http://www.diynot.com/forums/viewtopic.php?t=211524
http://www.diynot.com/forums/viewtopic.php?t=242738
http://www.diynot.com/forums/viewtopic.php?t=224751
& some more sobering just in case you think it’s all a load of old tosh:
http://www.solidfuel.co.uk/main_pages/news.htm
http://www.dailymail.co.uk/news/art...wood-burning-stove-leaks-carbon-monoxide.html
Also you can get quotes from local independent HETAS installers who will self certify:
http://www.hetas.co.uk/nearest_member
