First radiator come on when heating off
5 Feb 2007
Liverpool
I have a Vailliant eco tec pro 28 boiler and wireless salus controls. I have my stat set to snowflake which is just froast protection but sometime the radiator what I have goes warm even though the burner sign is not showing on stat. Can aayone help with this ?
thanks
Hi diycooper,
I'm a bit out of touch with current boilers, so I don't know your particular model, but most combi boilers need to "dump" any heat left in the heat exchanger when they turn off to prevent overheating when the water flow stops. A way to do this is via the heating circuit.
If you run the hot water and turn off, the excess heat is pushed around the heating circuit and a rad may heat up briefly. Chances are if you turn that one off the next in line will start doing it :) The longer the water is run the more noticable it will be, usually showering or running a bath causes it to be noticed.
Regards,
footprints
Noticed again today now 2 radiators are coming on. If the diverter is leaking hot water into the system can this happen even if hot water has not been used ?
thanks
