Fitted new Radiator now system does not heat
12 Oct 2008
Yorkshire
Hi
This is my first post so will start with a big hello :D
Ok I wanted to replace a Radiator in my kitchen, I went to the boiler and turned off the water inlet valve, drained the whole system (though why I did not just close the water inlet vlaves on the other Radiator I don't know) anyway drained the whoel sytem, fitted new Radiator all wentt well, turned the mains water valve back on and the system started to fill, when it had reached the correct pressure I turned on the hot tap, no hot water tried the central heating the same.
It seems to draw water and I can hear the pump running though the water does not heat
Is there air trapped in the system, I have used the key to bleed the Radiator's but still the same problem,What have I done wrong ??
Boiler is as follows - Vokera Excell 80 SP
many thanks for taking the time to reply
