fitted Wardrobe advice
5 Aug 2021
I'm about to install some fitted wardrobes and would like some advice please.
On one wall the configuration will be: 600mm Wardrobe + 1000mm bridging unit + 1000mm bridging unit + 600mm Wardrobe. This will leave me with around an 85mm gap. I could simply put a 42mm filler panel each end. However i'd like to increase the 2000mm gap between the wardrobes.
I'm wondering what it would look like if i put filler panel (matching in colour) between each unit. So it would be 3 spacers in total probably around 25mm each.
assuming the wardrobes have overlay doors -you could put some trims in the same thickness as the doors, leaving enough gap for the doors to open -if you make them flush with the face of the doors
Thanks. That's a great idea, I hadn't thought about that. I automatically thought of putting them flush with the carcass. It was this visible gap that was concerning me.
Wouldn't more wardrobe space be better?
600 + 600 + 1000 + 600 + 600 + 600 - leaving just 50 to be filled.
This is just over the bed. Main wardrobes on the other wall.
