fitting a cat flap
11 Jan 2008
Yorkshire
Does anyone know if it s possible to fit a cat flap in a uvpc double glazed back door?
Yes.
If it's a UPVC panel then just cut your hole out of it.
(Take the panel out of the door first)
If it's a glass panel then you'll need to have a new D/G unit made with the correct sized hole. There is usually a template that is supplied with the cat-flap which you'll need to give to your unit supplier.
