I am trying to fit a shower screen, but the wall is not flat. The wall bracket (which will hold the glass panel) is 6 tiles high, and will be position roughly here:
And it can either fit flush to the bottom two tiles, with a gap between the bracket and the wall at the top of the bracket:
or it can fit flush to the top four tiles, with a gap at the bottom:
The latter is the lesser of the two evils, but still not ideal. The gap at the bottom will be about 2cm. Two problems that I can see:
1. The gap will need cleaning. Not impossible, but a pain.
2. The bottom screw which should fasten the bracket to the wall will (if used) go across that gap, and so not be much use unless I get some kind of spacer (pile of washers, or a rubber spacer possibly.
Is anyone aware of a better way of doing this, or any products which can fill the gap without looking awful?
All help much appreciated. Thank you.
