Hi- my structural surveyor has recommended a ceiling void RSJ. One side is joists at right angles, so I guess they will fit into the RSJ web which is fine, but the other side is a chimney breast, which is also fine. However!Upstairs on the rising chimney breast is a tiled fireplace I'm keeping, and on the back of that chimney breast, a room with 1920's glass panelling stuck to the wall..... Now here's the not very exciting question: How can the wall be propped up by acrows/ Strongboys to get the RSJ flush with the bottom of the upstairs glass wall/ breast if I can't get to the wall because the fireplace/ glass panels are in the way? (All this assumes I believe I'd need to insert the acrow supports in at about skirting board height upstairs as the only way to slide the RSJ in). Should I just drop the beam down to a height where the acrows prop up a brick or two below the fireplace/ glass panels and accept I'll see more of the beam downstairs..... or is there a genius out there who knows a way around this?!? Hopefully- Richard.
