Fitting a motorised valve - whats the best way to control it
1 Mar 2008
Norwich
Hi Guys
I have combi system which I don't run off the time clock preferring to manually switch on and off.
At this time I find myself running up and down to turn off the upstairs rads (on thermys) during the day. So I want to fit a motorised valve to isolate up-stairs to save my legs!
However the way the system is piped doesn't give me many options and essentially I want to fit the valve with just some form of switch downstairs, so my question is whats the best way to do this a basic time clock?
Many thanks :)
Depends on -
A) Presumably the upstairs rads have their own flow pipe to allow this
B) How simple or complex you want to make it, ie. you could have just a basic switch to open/close the valve, possibly add a seperate room stat for upstairs, or you could have a single channel programmer to time the valve, possibly with a stat as well.
Depends on your needs and the system.
yes - the boiler flow and return goes straight up-stairs and before feeding any upstairs rads drops to the ground floor and then continues to feed the upper floor; so would cut in just after the downstairs drop and then control where they drop down which conveniently is in the kitchen.
Although pretty good on the plumbing bit of a dunse on wiring so would prefer the easy option - what sort of basic switch would I need?
thanks
