- Joined
- 8 Mar 2010
- Messages
- 313
- Reaction score
- 7
- Country
What ho one and all,
Fitting a replacement wash basin; annoyingly, it is a few mm smaller that the one I have removed so will require some silicone 'remodelling' to fill the gaps. But that is a different issue.
Am using the original pop-up waste fitting as the visible part inside the basin is in good condition.
However, the squidgy washer/sealer is not the same profile as the basin is 'slightly' different from the original.
First question; what is this (red arrow) washer / sealer / gasket/ actually called and can one usually buy a replacement?
Second question, in searching Dr Google for an answer to the above, I found one site that suggests using silicone on the green arrowed areas. None of my basins have silicone in these areas; is this something that I should do?
