Just wondering on which way you prefer to fit security lights as have been having discussions and constantly disagree with my Colleague.
My way is to run the light straight from the lighting circuit with some 1mm 3 core cable, through the wall and into the Security Light. the light MCB can be the switch to turn on and off if needing to change bulb etc. This way no other switches / FCU's etc. (and yes the MCB will be correctly rated for lights and new security light)
His way, run a FCU from the nearest ring main, then again through the wall into the security light. His reasoning would be that you have an isolated fuse specifically for the Security light and thereofre no need to disturb other circuits.
I still think it is more expense and hassle to fit a FCU, use some 2.5 twin and earth, then 1mm 3 core cable and then the light where my way does the same job, you wouldnt be repairing the light at night time so therefore dont need the light circuit on anyhow
we have a £10 bet on who has the higher number of agreements so please favour me
Oh, and just to post, we both disagree with another "electrician" we know who says just drill through/near the window frame and attach a plug to the nearest socket . he is 57 though so is from the cowboy school, still hes good for his crack
