We are currently renovating our house; the TV aerial is fitted in the loft (how it was when we bought the house). I want to put TV points in each of the 3 bedrooms and the usual one in the lounge, so thought it’s probably best to just replace everything and install an aerial on the gable end or move the one thats in the loft. I have a few questions that I wondered if anyone here who is experienced could answer.
1) Do I need a master head amp due to the amount of splitting I'm doing? (I suspect that I will, but thought it best to check)
2) Is it better that the cable from the aerial / amp is ran along the outside of the building where possible and then directly in to the house at the point where the back box / face plate is located? Or can I run the cables part way down the side of the house through the wall and then through the ceiling / floor void space (the only reason I'm asking is that I'm not sure if the electrical cable for the ring main etc will interfere with the signal, of course if I install it this way then I would where possible route the aerial cable away from the electrical cables).
Thanks for your help.
