Fitting an attic ladder
12 Feb 2015
Surrey
6 years ago I bought a loft ladder - the carpenter made an opening with double joists and noggins and the builders fitted the case in the ceiling, but left everything else in its packaging.
I tried to fit it a few days ago and it was a disaster. It uses two springs to hold it in place but the strings also pull the trap door and the ladder which is attached to it towards the hinge end of the trapdoor so hard, that the door catches on the hinge side, and will break the ceiling if I try to open it. No amount of readjustment helps as the strings pull so hard. I used 5x80 screws to hold the hinges in place, but even if I had used larger screws, the constant pull of the strings, let alone the action of opening and closing would again pull it towards the one end,
So I have removed the springs for now and have left it open. It now works well and does not catch anywhere. But it is very dangerous.
I had a look at toolstation and it looks very much like the "Werner Timberline Loft ladder Kit 1.13m x 0.55m x 0.28m"
Has anyone fitted one of these to advise me please?
Maybe better to use a hook to pull the ladder down separately from the hatch and add a secure latch to keep the hatch in place when closed
Have you got the installation instructions?
Yes, followed to the letter. With the springs out it works perfectly. The springs pull the trapdoor so hard that it catches and damages the hinge side area/ceiling etc.
Because the whole assembly is shockingly bad quality I am thinking of changing for a decent model. I am heavily restricted by the existing opening.
I'd be inclined to suspect the springs are overtensioned and the fixing points should be closer together.
But I haven't got a similar ladder to compare it to, and spot the differences.
If nobody here has one, is there a shed that might have a display model you can look at?
Ugh. I think your link is wrong.
I would use long eyebolts
You can get a cheaper version sold as fence strainers. You put the end through a bracket and tighten the nut to increase tension.
