Fitting an oven with hob
27 Dec 2013
London
This is my first post so please take it easy :)
For the last few weeks I have been trying to get an oven fitted. The setup was a 6000W hob plus a diplomat single electric oven both connected to the same 32A circuit and isolation switch, never had a problem until the oven died.
First we got a 16A Bosch oven, the John Lewis fitter said we needed a 16A circuit and should get a 13A oven or 32A oven. Which seems rather strange, wouldn't a 32A oven blow the circuit?
So I ordered a 13A oven from Curry's, the fitter said that the 16A oven would have been fine but the 13A oven is not. :confused:
As the old setup worked flawlessly before what should I actually try to get and how should I have it fitted?
Curry's don't have any electricians. John Lewis would seem to be the same.
Connect them both to the cooker connector but use 4mm² heat resistant flex.
This will likely mean you have to change the flex on a 13A oven if it came with a plug.
Wouldn't it be better to fit a single 13a socket (good brand like mk) on cooker circuit to plug the oven into? Avoids voiding the guarantee and sourcing cable etc.
Not really and it won't void the warranty.
Easier to buy a piece of flex than source back box and socket and chase wall and fit. :)
