I know this is potentially dangerous but needs to be done.
using correct gear, electricians gloves, VDE cutter/ stripper and phillips, goggles, rubber mat, no other metal near, CU switched off, how many of you would cut the meter tails (individually!) , strip and feed into plastic isolator enclosure.
I presume neutral first, then shield terminal with piece plastic inside enclosure while you put live in. "Guarded" by 60A fuse, would this be safer than taking ceramic fuse out of old cast iron Lucy enclosure - and obviously cutting seal.
Its just like welding in reverse.............
