Hi folks,
I’m looking for some of your experiences with excess loading and services fuses here.
I have set up a temporary site supply for a large office site using an existing supply from what used to be a house on part of the site (now all one building)
The supply was installed in the 1930’s and is a paper/lead cable which had a cast iron cut-out but the DNO have replaced it with a modern plastic one last month as the meter fitter refused to connect the iron one which only had a 40A ceramic fuse holder.
The new cut-out has a 100A fuse and existing 16mm meter tails with new meter to Henley blocks
I set it the site up with electric shower, cooker and sockets/lights. No problems. Domestic type setup.
Problem now is that security staff are now living on site (I wasn’t informed of this happening). They have about 8 convector heaters and have installed another 3kw water heater plus washing machine, dishwasher, dryer etc. and loads of floodlights.
When I called in to check round there was a report of a ‘hot’ smell’ around the main supply point. The service cut-out, tails and meter were all too hot to touch and there was oil starting to drip from the main cable.
I put my clamp meter on the tails and the load was 183A! After switching off some heaters and appliances I got the load to 105A and it has been running between 70-120A for a few days now, oil has stopped leaking!
The new supply is getting connected in 2 weeks so I’m not too concerned long term, but how did the 100A service fuse not fail at such a high load? What load would an old supply cable maybe equivalent of 10 or 16mm take before the cable failed?
