Fitting Lino
3 Feb 2006
Good evening
I am a DIY beginner so please be a patient.
Looking to change the lino in the kitchen and bathroom and wondered how hard the process is.
Does anyone have any tips?
George
do it in the garden.
lay new lino on top of old lino and mark round it
cut with sharp utility knife
You do it in the garden as cutting the loge carpet while cutting linio does not go down to well (no, i didnt do it)
and dont turn the lino over buth should be face up or face down (not one of each)
fitting lino is very difficult. even seasoned carpet fitters frown upon, and shy away from fitting the stuff.
you have been warned.
ah, but he said change it, which imply he has one fitted already, hence use it as a template
If using as template I would cut over size, then trim when laying. Unlike carpet 1 wrong cut & it will show, Get it laid by a pro worth it.
was you drunk while writing this ? need a little editing i think :wink: Any way. are you talking about lino or vinyl? lino cant be bent with out cracking as vinyl is flexible! Either way i advice you to template if diy. But make a template , dont use carpet you took up. If you dont know how to template ask and either i or someone will tell you how.
no, despite my user name i dont drink
I am bad with spelling (at least my grammer is better than yours)
Why make a template when he has one?
I think it must be you that has been on the drink, where did the op say carpet? he didn't, YOU are seeing words that are not there (are you sure its not you that has been drinking? :wink:)
the op wrote
george0401 said:
Good evening
George
(no matter how many times i read it, i can't see the word carpet (unless i do the following)
george0401 said:
Good evening
Looking to Change the lino in the kitchen and bAthroom and wondeRed how hard the Process is.
DoEs anyone have any Tips?
George
you have been busy! I like the bit where you manage to spell carpet. You should be on master mind or something :roll: Miss understood carpet template after reading your bit
Still trying to make sense of it and thought you on about carpet or what ever your on about? No harm done but for other people trying to template you shouldn't use carpet as template.
