Morning All,
Hope someone can help as I am a true novice to wiring and not sure if I am doing something stupid.
Basically I am hooking up a New Outside Light to the old wiring and cant get it to work.
The old Outside Light wasnt working and was a bit rusty and old, so instead of just swapping the bulb, I bought a whole new Unit that has Sensors on it.
Basically the way it is setup from checking the Socket, is they have the Wall Switch which inside has 3 Wires
Red Wire
Black Wire
Green/Yellow(Earth) Wire
Green/Yellow wire is I presume the Earth and is not connected to anything, just covered with casing and wrapped securly.
The Red and Black wires are attached to a plastic block which screws onto the back of the Switch.
There is then a Grey Plastic casing leasding outside and along the wall to the Light Unit.
Now my understanding is the Red Wire is Live and Back wire is Nuetral.
On the Light Fitting, there is a choc block which has a Yello cable attached on the end slot, then 3 wires being
Yellow/Green
Brown
Blue
Now the way it says to hook it up is Blue to Black and Red to Brown and yellow/Green wires together.
I did this and then set the Sensor lamp to Test, and switch the light on and nothing happened.
I double checked and everything was plugged in okay, so just wondered what could be worng, have I got it wired wrong or what Issues can I check like cable testing etc
Cheers in advance
Then on the Light Unit there is a Choc Block in it with
Red Wire
Black Wire
Yellow/Green
Brown
Blue
Cheers in advance
