Fitting register plate inside existing chimney
14 May 2010
Merseyside
I am installing a wood burning stove in my property but am having some difficulty in securing the bracket on the inside wall of the chimney which will hold the register plate.
The problem is that the bracket needs to be fitted high enough in the chimney so that it can't be seen but also so the access hole in the flue is not blocked. But it is too high up for me to get the power drill in to drill the holes and fix it in place.
Can anyone provide me with some solutions to this, because i am getting a bit frustrated as i am desperate to start using the stove, especially now the weather is getting so cold.
Thanks in advance
Ian
