    Dismiss Notice
Fitting/ screwing toilet to uneven floor
Discussion in 'Plumbing and Central Heating' started by XanderHarris, 17 Nov 2013.
  1. XanderHarris
    XanderHarris
    4 Mar 2013
    132
    Thanks Received:
    Bradford
    Country:
    Hi what's the best way of fitting/screwing down a toilet to an uneven concrete floor?
  2. Sponsored Links
  3. buck51
    buck51
    15 Feb 2008
    894
    Thanks Received:
    103
    Manchester
    Country:
    2" bolster +2lb lump hammer
  4. rego
    rego
    26 Jun 2005
    153
    Thanks Received:
    25
    Tyne and Wear
    Country:
    I would try to make some sort of rubber gasket to sit under pan then when you tighten screws you should get no movement when sitting to do the biz
  5. Blagard
    Blagard
    9 Feb 2010
    1,560
    Thanks Received:
    275
    Leicestershire
    Country:
    The traditional way was to bed the pan on mortar.
    To make up small irregularities I found the two part fillers like P38 and Ronseal high performance wood filler work well. Because they set quick you can get on with the job in no time. Bed the pan onto it where it is needed and in ten minutes as it sets cut off the excess. Then tighten up your screws, Job done!
  6. Or rapidset cement.
    • Thanks Thanks x 1
  7. Sponsored Links
  8. HERTS P&D
    HERTS P&D
    9 Apr 2010
    11,952
    Thanks Received:
    1,821
    Hertfordshire
    Country:
    I wouldn't use wood filler!
    Andy
  9. newbuildinstaller
    newbuildinstaller
    3 Jun 2010
    7,553
    Thanks Received:
    1,673
    Durham
    Country:
    I wouldnt cement it either!! If you ever need it out again you need a new toilet!!!!!!!!
    Self leveler on the floor or chisel and hammer as already suggested!
    I did a block of flats in Byker the council had cemented them all down every toilet came out in at least three bits!?!?!
    CARP IDEA imho
  10. Blagard
    Blagard
    9 Feb 2010
    1,560
    Thanks Received:
    275
    Leicestershire
    Country:
    No doubt you have your reasons, but I am talking about the two part type only. Which is also used in it's P38 form for car bodywork repairs. So don't let the wood bit put you off!
    The first time I used this was on a wood floor and it was the uneven pan I had to correct. Same WC has been down 25 years and still solid. So it does work. I have also used it on quarry tiles and again no problems. Th principle is not to try and stick it down but to use the filler as a packer that moulds itself perfectly between the surfaces.
    The floor can be perfectly level and the pans be the problem so even a floor leveller will not always work
  11. Burnerman
    Burnerman
    7 Feb 2008
    22,578
    Thanks Received:
    4,399
    Northumberland
    Country:
    Spend a bit of time with an angle grinder and a stone grinding disc to get the floor as flat as you can, then set the pot down on a thick squidge of silicone.
    (Bet those flats were in the Byker Waaaall.....had similar issues with the Killingworth concrete jungle :p )
    John :)
  12. Blagard
    Blagard
    9 Feb 2010
    1,560
    Thanks Received:
    275
    Leicestershire
    Country:
    Sounds like the job was done well and proves it is fine. How often do you remove pans for re-fixing? Mostly it is remove to skip! However all the ones I have taken out simply left a hump of mortar on the floor to remove
    • Thanks Thanks x 1
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
