I am fitting some new windows and have a few concerns.
The seal units have a black tape around the outside, but I can see that the black sealant between the glass panes, sometimes protrudes up to 2mm beyond the perimeter of the glass. This is mainly, but not always, in the corners.
When setting the units into the frame, using bridge/glazing packers, I assuming that it would be bad to rest these raised areas on the packers, which may mean that the packers are not going to be in the corners, or evenly spaced in the bottom of frame. Is the posiiton of the packers critical?
On side opening sashes, I'm assuming that I need to put to packers in the corners, to toe & heel correctly, so I may have to rest the unit on the raised bits regardless. Will this be a problem.
Finally, on larger windows eg 1m wide, would you still only put packers in 2 locations?
