can anyone explain how to wire 6 spot lights from a single feed in a bathroom please. i am fitting 5 normal and one enclosed above the shower cubicle. thanks
What sort of light wiring do you have at present. loop-in? (ie you have two or three cables going to the light fitting) or is there a junction box in the roofspace with only one cable going to your light fitting?
You will need to wire things up differently depending on what type you have (post a photo will help).
The new lights effectively connect where the lamp of the existing fitting go. the old fitting is removed and an appropriate juncion box is used to replace it.
Whjat sort of lights are you planning (dont know what 'normal' means)?
Are they appropriate for the bathroom zones?
What steps are you taking regarding equipotential bonding?
Have you remembered to notify the local authority?
