Hyperthetical at the moment, but if I were to fit a surrey flange what would be the correct procedure for draining down, ie should the whole of the HWS Vessel be drained?
just isolate the feed gate valve to the cylinder and run the hot tap to till it stops
then you can put a cloth around the pipe exiting the top of the cylinder and release the pipe and fitting and fit the surrey flange.
Thanks guys, just close the cold feed to the cylinder and drain hot at lowest point.
Also while on the subject, I take it I will need irons for the Surrey threads? ?22mmX1" Would I be feeding the shower pump in 22mm or 15mm. If 15mm I would then need a reducer from the 22mm? Thanks again
If you do get the one from screw-fix make sure its the right size for your cylinder as they sell a 1" one as well. And remember if you isolate the cold feed only you will be draining the cws tank (waste of water) bung it or as seco said shut 3/4 " gate valve (if it closes)
