    Dismiss Notice
FITTING YALE LOCK
Discussion in 'Windows and Doors' started by TARGET1, 28 Nov 2010.
  1. TARGET1
    TARGET1
    28 Nov 2010
    2
    Thanks Received:
    Surrey
    Country:
    Am replacing Yale Rim Lock P1....ok so far, but when trying to fit lock body on to mounting plate am having problems....is there a knack ? Unable to locate left hand pin on mountning plate at an angle........
  2. ladylola
    ladylola
    19 Dec 2009
    3,314
    Thanks Received:
    289
    Staffordshire
    Country:
    There's no knack as such , it should just fit quite easily. One thought , are you trying to fit the new lock to the old mounting plate? Won't work most likely.
    Photos may help get you an answer.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. TARGET1
    TARGET1
    28 Nov 2010
    2
    Thanks Received:
    Surrey
    Country:
    Hi Thanks, am fitting all new, but
    lock body seems difficult to locate on left hand locating pin...... ? ? :D
  5. ladylola
    ladylola
    19 Dec 2009
    3,314
    Thanks Received:
    289
    Staffordshire
    Country:
    Ok , try taking the mounting plate off the door and assembling the whole thing off the door, it's possible something is bent or misaligned and it will be clearer to see it off the door. When you can fit it together off the door you can then go back to trying on the door.
    • Thanks Thanks x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
