Although I'm sure this should have been done differently, and I suspect there might be several wrongs in it, rather than start all again I need to rectify it so that I can finish the chipboard floor to the door opening.
Suspended timber floor which is bolted up to the inner leaf. Top of the Inner leaf is approx 40 below top of joist height. Cavity isn't filled between it.
[img]https://thumbsnap.com/s/hHoIoTtX.jpg[/img]|https://thumbsnap.com/hHoIoTtX
[img]https://thumbsnap.com/s/cMlk5dV1.jpg[/img]|https://thumbsnap.com/cMlk5dV1
The timbers are insulated between with 75mm foil backed insulation so ideally want to finish over this with some insulation to prevent cold bridging but don't want to introduce damp.
Whats the best way to do this? DPM is directly under door.
