Hello,
I have started on the framework for my decking outside (fixing 2 beams to my walls), I had a nightmare yesterday with the special bolts (the ones with outer shells that are supposed to stay in the brick and open up) anyway I have given up on these bolts as they wasn't grabbing, I have bought some long screws were the rawlplug is as long as the screw, apparently the plug is supposed to sit in the wood and the wall. I bought the right sized drill bit and drilled deep enough (with a little to spare) I made sure the hole was cleared out but the screws would only go in so far and wouldn't tighten up, I even snapped one screw tightening it up.
What am I doing wrong? any advise/tips or should I give up??
Thanks in advance
Thanks in advance
