Fixing 40mm celotex under rafters
1 Dec 2008
Nottinghamshire
Anyone know of a good fixing for putting the above onto a pitched roof prior to boarding out?My local supplier doesnt stock them anymore
tried the roofing section?
do you mean actually to the rafters as is sitting under them, or do you mean between the rafters as in flush with the underside?
if the former, gripfill along the rafters and stick the sheets on then use longer screws through the plasterboard? :)
yes its under the rafters,i did think abt gripfill,but if uve got to screw them temp,then you might as well do it that way anywya?
cheers
not entirely sure if gripfill won't eat into the foam, but if they're foil covered then i don't think it will..
