Fixing a 800 x 800 mirror onto bathroom tiles
1 Mar 2011
West Glamorgan
Hi
I am planning on getting a 800 x 800 bevelled edge 6mm thick bathroom mirror and would like to know the best approach to fix this onto a tiled surface?
Would it be best to use mirror clips or mirror fix adhesive? to fix onto the tiles?
Whereas I would use mirror adhesive because I wouldn't want to see any fixings.
A wooden baton, held in place with a tiny amount of hot melt glue will support the mirror overnight.
Hi
I recently "glued" a 1000mm x 1000mm 6mm thick mirror to my bathroom wall.
I used mirror adhesive... you can get stuff from places like Screwfix (the irony) for about £7 for a tube (you'll need a gun applicator as well of course). Make sure you get "mirror adhesive", apparently regular "no more nails" type stuff is not suitable as it will react with the mirror backing.
As already mentioned, you just need to retain the mirror in place to let the thing set properly.
Mine hasn't fallen down...
(yet)
I've used Stixall before now, works well with good grab, fully waterproof, claimed 40 year life and doesn't appear to react with the mirror backing
TBH I haven't had any problems using bog standard silicone provided that the mirror has a foil backing
