Hi all,
At the weekend I will be installing a 3ft high closeboard fence on top of my yard wall. The wall is 2' high on the inside and and around 3'6" on the outside and is in a fairly sheltered location. It is double skinned and made from pitched stone on the outside and 4" solids on the inside. The coping is made from indian stone and is about 1.5" thick and 45cm wide. It is bedded on a 1" thick layer of mortar and the wall was backfilled with mortar to about 1 course down. I hope this will give me a substantial fixing surface for whetever fixing I choose to use.
...which brings me onto my next question. I was going to use shield anchors but I have been advised by the fence supplier to use what they call 'Thunderbolts' (self tapping fixing that screw straight into pre drilled holes). They said that shield anchors may work loose in the mortar over time. Is this likely to happen? Does anyone have any experience of 'Thunderbolts' or similar types of fixing for this purpose?
Finally the Indian stone coping has an uneven finish - whats the best way of levelling the Metpost brackets?
Any advice is much appreciated!
Thanks, Owen
Thanks, Owen
