Fixing blind to steel lintels
13 Oct 2016
Ordered vertical blinds for our 8 windows and have discovered that the lintels are made of steel. I know that I will have to drill holes into the steel to attach the fittings but never having had to drill into steel before, I am unsure of the type of bit and the speed I should use on the drill. Can someone help please?
Twist drill, preferably M42 HSS (often called "cobalt steel") will do the job. Assuming the steel is beneath plaster or plasterboard maybe drill down to that with a masonry bit first (to save your HSS bit). Drill at 600 to 1000 rpm or so, no faster. If drilling larger than 4 to 5mm pilot with a smaller diameter bit first then switch to the right size.
As an aside, it is probably going to be more productive to fix a softwood batten (2 x 1 or 3 x 1) to the wall and then fix your curtain track/rail/blinds to that
BTW what fixings were you going to use to attach the gubbins to the lintel, and do you know what type of lintel are you dealing with?
Thanks for the easy to follow instructions.
Did exactly that in my previous house but not possible in this one.
1. BTW what fixings were you going to use to attach the gubbins to the lintel, and
2. do you know what type of lintel are you dealing with?
1. Self tapping screws.
2. Apart from the fact that it is steel the answer is I don’t.
Have just fixed the first bracket in place, and it was so simple after drilling the pilot hole. Thanks mate.
