Fixing Downpipe to corrugated sheet wall
17 Apr 2015
As per the title, really. Any tips? I’ll put a swan neck on it to bring it close to the wall but can’t quite see a neat and fairly waterproof solution with normal brackets, so guess I’ll need some kind of spacer. It’s those coroline bitumen sheets, normal rounded profile, sheets mounted vertically. Any thoughts appreciated thanks
Is this a large run? Not something I’ve seen anywhere local to me
No, just a vertical run about 2m max. I’ll probably just secure it at the bottom unless I discover any other options.
Could do top and bottom? Maybe use a sealant if you wanted to secure to the corrugated sheet?
