Fixing plant supports to Durafence composite panels or to the Duraposts
11 May 2004
Hampshire
I have been 'volunteered' to help a neighbour who has had composite Durafence panels with Duraposts installed (that are 'H-shaped', I am told, so presumably steel), and now wants to support some plants. They envisaged some screws with twine, for example, fixing to either the panel or the adjacent posts.
Are there any experiences with appropriate fixings - without distorting the materials and spoiling the clean lines?
I guess the internal ribbed structure of the panel would exclude hollow wall-type fixings, as you may hit one of the internal ribs. The panel's external wall thickness and its relatively soft material is not likely to be enough bite for a self-tapping screw, and just pull out. Is that right? Through fixings would look a bit 'Clampetts'.
A pilot hole in the steel post sounds like a good way to break several drill bits, but a self-tapping screw into that might work.
Actually, my preferred option is to use free-standing posts or tree stakes for supporting plants, but I would like to explore the options.
Any thoughts?
How about, something like those U shaped brackets, made from flat strips? The same idea, as used to hang clothing, over the top of a door, without screws into the door.
Duraposts are steel, but only of the mild variety, so there is no reason on earth why a drill bit should break when drilling it.
You're right that fixing into the panels would be a poor idea.
Does this neighbour get on with the one next door, or is that you?
Duraposts have holes, but only on one side - I'd suggest drilling right through some and out the other side, and put a stainless steel bolt or machine screw all the way through from the neighbour's side, but they'd need to help by holding a screwdriver or spanner to stop it turning. Use ones long enough to protrude so that twine can be would round, or add some sort of eyelet held on by another nut.
