I am wanting to fix some steel posts to my driveway (post and chain fencing). The posts have a 100mm square plate welded to the bottom with holes for 4no bolts (I did think of only having two fixing per post but I understand Tarmac is particularly hard to fix to so the more the better).
Should I be using rubber sleeved anchor bolts? and if so is it a case of drilling into the hardcore (I need to check depth) slotting in the rubber sleeve and then fixing down with the bolt?
If this is the solution does anyone know where I can get hold of these bolts as all I can find online are the metal sleeved anchor bolts? or would these be OK instead of rubber sleeved ones?
If there are any other ways to fix the posts these would be greatly appreciated.
Ted
Ted
