fixing shower riser above bath
16 Jul 2009
Hull
can you fix this ok to tiles or is wood needed to be put in the wall?
You'll get a good fix into the tiles alone - just drill carefully so the drill doesn't wander. No hammer action until you've cut through the glaze!
John :)
As long as they don't want to swing on it ;) then 6mm tile drill & good quality raw plugs, don't use the ones you get with them, they're usually carp.
