Hi all,
I have a unit, which hooks onto metal plates that you fix to the wall.
Im fixing 2 of these plates to the wall one for each side of the unit to hook onto. Problem is, the holes in the plates are quite close together, 1.5/2 inches between them. As its a heavy unit i wanted to use wall anchors but ive realised because they spread out behind the plasterboard i wont be able to use 2.
Is there any way i can use an anchor on one screw and some other type of plasterboard fixing which doesent open out behind the board as the other screw?
If so which is the best type that wont require space behind the plasterboard?
