Good Afternoon,
We have a flat roof with felt covering on our garage and extension, the garage roof is a much smaller area and is slightly shorter in height then the extension. The garage roof is leaking, we have spotted watermarks on the ceiling of the garage.
I have a couple of questions that you may be able to answer for me, thanks in advance.
1.) How exactly is a flat roof constructive? - I take it that the roof is made up of joists with decking over the top of the joists and the roof covering over that. Would that be correct?
2.) The flat roof on the extension does not seem to be leaking, as these two roofs are on separate levels would it be possible to install a new EPDM rubber roof on the garage with out disturbing in the felt roof on the main extension. I can supply pictures if required.
3.) Also could somebody please comment on DIY roofs that are sold by http://www.diy-flat-roof.com/. How easy would these roofs be to install
As this looks like the route we may take.
Kind regards
Ian
Kind regards
Ian
