Flex inside light fixture
29 Jul 2010
I'm replacing a standard lamp fixture and ceiling rose with a halogen light fixture. The current is on a loop and the light is 2-way switched - lots of wires. The new light fitting comes with a choc block already attached, however as it is a 5A block, I can't get the the three wires into the terminal of the block. Therefore, I've going to connect two of the wire in an intermediate choc block and then connect this to the choc block in the fitting. Space is already limited inside the fixture so I have used flex wire, i.e. multiple stranded wire, to connect the intermediate choc block to the final terminal block. Would there be anything wrong with this?
On a related point, I'm a little confused about the colours of the wires on the existing ceiling rose. The house is brand new and so uses harmonised colours. However, I was surprised to see a grey wire connect to the neutral terminal of the ceiling rose. I have transferred the connections to the corresponding one on the new light fitting and everything works fine. Can anyone shed some light on this?
Be better if you could get rid of one of the choc blocks, but it will be ok.
The grey wire to neutral is correct, but it should have a blue sleeve. The reason grey is used (even if a black wire is available) is to educate people that black is no longer used as a neutral.
Many thanks for your help & for the info RE the grey wiring! My main concern was using flex wiring - the same stuff you get in appliance cables.
Very funny :rolleyes:
Sorry, couldn't resist!
As long as the wire is the same size or bigger than the wire from the light fitting it will be ok.
I just snipped off some of the wire from the existing pendant light that I was replacing - so I hope that it's the right size!
Thanks again.
No such Regulation. That is simply NICEIC policy for "deneutralisation" of black. It is equally correct to use a black core and sleeve it blue.
So long as it is correctly identified, e.g. with sleeving, then it complies.
Well this one didn't have a sleeve, it was simply grey. Looks like I'll have to take the fixture down and fit a blue sleeve. Wonderful!
Indeed it was NICEIC who stated that using grey for neutral would drive away the use of black for neutral.
There is a more logical reason for this, especially if you look at three phase
The old 3 phase standard was
L1 = red
L2 = yellow
L3= blue
Neutral (if used) = black
the harmonised colours are
L1 = brown
L2 = black
L3= grey
Neutral (if used) = blue
There's no regulation on which should be used for which in lighting circuits but the conductors should be sleeved to indicate their actual useage.
Brown = live (or may be live eg in a switched circuit)
Blue = neutral
etc
edit Yes I know live = line = phase = hot
No such Regulation.
Where did I say it was a regulation?
Seems you're only here to start arguments, can't you find a pedants forum then you'll have loads of people to argue with.
I'm not here to start arguments. I simply think any suggestion that using grey rather than black oversleeved blue is somehow "better practise" is unhelpful and misleading. I'm not trying to suggest that this was your intention.
It is equally good practise to use either.
