Flexi to isolator
18 Jun 2011
Yorkshire
Hi
Is the male thread on a 15mm compression isolator the same as on a WC inlet ! .
and do they do a 15mm to 10mm flexi compression fitting both ends .
cheers
spike
Reading between the lines here ,are you trying to connect WC to 10 mm supply pipe ,with an isolation valve and a flexi hose ? If so buy a mini isolator from screwfix ( code 91386 ) it is a compression fitting , 10 mm at one end 15 mm at the other. The flexi hose goes onto WC valve ,a short piece of 15 mm copper used to join the flexi to the isolator 15 mm end,and the 10 mm end direct to the 10 mm supply pipe.
Hi
Thanks for your reply , yes that is exactly what I am wanting to do ,did not think they done a 10x15 isolator Valve ,perfect thank you very much .
cheers
spike
