flexible monobloc tap connectors >500mm
70mm is about 2-3/4 inches. What length do you really want?
Presumably you mean 700mm.
Just screw the ones you linked to onto 600mm 1/2" to 15mm compression flexies.
Ahh yes, my mistake.
You are quite right, I need the connectors to be at least 700mm long.
I'm trying to avoid any unsightly 'knuckles' as it were so if possible I'd like continuous flexible tubes.
NB I've now edited the original post.
Wickes do 1000mm long ones but they are not designed to fit into a monobloc tap. Very unlikely you will get one that long to screw directly into the tap.
Did you ever find any?
I need some to go up into a very tall tap (lose 200 mm) and then down below a very deep sink and don't want connectors behind the sink.
Also its a granite worktop that goes on top of the sink....
I need some of these also. I have a wall hung sink and I need a pair of monobloc connectors at least 500mm long to go right through the wall to connect to the pipework behind.
