Hello All,
My first post so please be gentle!!
I am currently replacing an old single skin lean-to, with an extension. I have kept the original wall, studded it and insulated it with 85mm plasterboard backed insulation.
I am not working off plans, but am using a Building inspector, and so far, he's been happy with all my work. He also stated that because the floor is already in situ, and insulating on top of it would be impractical, due to it creating a step up, I do not need to alter the floor. This was good news until I removed the wall separating the extension and the old room, and found a 10mm height difference.
After getting into a discussion with a local builder in the pub, about different flooring methods, he stated that he had done two builds recently, where he lay 100mm celotex and dpm on top of 100mm crushed concrete (blinded), and then glued tongue and grooved chipboard on top, with no concrete slab at all, which leads to my question, does this method seem acceptable. It is certainly appealing, and I will be asking my building inspector about it, but wanted to know other opinions first.
Any opinions appreciated.
Many Thanks
DBD
Many Thanks
DBD
