Hi all first post,
I am in the process of a self build conservatory, the base has been finished and the questions are to do with insulation of the floor which has been laid in by process of Hardcore then sand, Over the sand is a damp-proof membrane then the concrete slab.
Will it be ok to put 50mm celotex on the slab with 18mm chipboard flooring on top of the celotex? or would it be a better option to use a thinner insulation board and screed over the celotex? The final flooring will be laminate floor if this makes any difference to how its done. hope there is some suggestions for this?
cheers Dch
cheers Dch
