Hi All,
This is going to be challenging to describe but will try my best...
I am laying out the Flow and Return pipes through my floor joists (150mm high) and happy with regs on holes, etc. There is one particular situation where I need to go down a wall to feed rads but there is a joist butted against the wall. Not too uncommon I suppose. I need to surmount this and pass my pipes down the wall. There are two 15mm that I need to send down this route. The only solution I can see is a small notch at the bottom of the joist (2*15mm pipes).
There is no other wall that I can send these pipes down. I know it's not the done thing but can I have your views on this please and also whether I could strengthen the joist after doing this.
Thanks in advance.
Thanks in advance.
