We've had the old floor tiles removed from our porch/lobby and in places the concrete floor below had come away with the tiles - we need to level this up as we're having carpet fitted instead of the tiles - I was planning to just use cement to do this. The depth varies (obviously - as it is uneven) but is no more than 1" deep, probably less and the affected area is approximately 1sq.m - about 1.2mx0.9m.
Will I be OK using cement to do this - or should i use something else. Any idea roughly how long it'll take to set/cure bearing in mind its less than 1" thick and in a heated room with good air circulation? Should i use 4:1 sand:cement mix?
Thanks in advance for any advice!
