floor screed and insulation question
29 Apr 2007
Surrey
Hi
we are about to insulate and screed our newly built kitchen. The concrete slab is in place and the plans state 85 mm of insulation and 75 mm screed wich is a total of 160mm. We actually have 200mm depth to fill and I would like some advice as to wether we should use deeper insulation rather than deeper screed?
id use all insulation persoally and chipboard.no drying out time,no moiture in the house,can work on it straight away,less depth of substance for insulation to take effect.
I'm thinking chipboard would move about? surely the insulation isnt rigid enough to support chipboard permantly?
chipboard would not move and the insulation would support the floor with no problems, go for it
Chipboard flooring in the kitchen?
url
never failed yet for me,unless you mop ya floor excessively.use the green stuff and make sure you glue the joints if you go down that route.
I would not even bother burning chipboard.
To say it is rubbish would insult rubbish things.
Go for a heavier screed. I do not trust screeds that float on insulation, so i would always tend to go for a thicker screed, to give it a better chance.
Lets not forget that you already have a dry slab beneath the inso'.
P.s. you would need to be completely insane to fit chipboard in a kitchen, particularly when you have an opportunity to lay a 'solid' floor.
